Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: Cruisin' in Neutral - Actually a blast!
  1. #21
    Member slcasner's Avatar
    Feb 2011
    Sunnyvale, CA
    Quote Originally Posted by drees View Post
    If you are engaging ABS - the brakes are plenty strong. Since all cars can easily engage ABS with a good stab of the pedal let's assume that the brake hardware is sufficient for now.
    Right. When I was driving on the track at Laguna Seca, I found that I needed to stomp on the brakes pretty hard in order to brake as late as seemed appropriate, but when I did so I could tell the ABS was engaging. That means there is enough friction between the pads and the rotors. Maybe there is just not as much power assist as people are expecting. Time for some leg exercises!
  2. #22
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    When I did the race school, we had trouble with the accident avoidance maneuver, but not in the way you'd think.
    The Roadster kept stopping way too quickly. We had to get it going pretty fast before we could get the ABS to trigger. And that was on deliberately wet pavement.
    So I think the brakes work pretty well.
  3. #23
    Electrics are back mpt's Avatar
    Oct 2008
    Warren, New Jersey, United States
    Blog Entries
    Quote Originally Posted by S-2000 Roadster View Post
    I don't see how this could possibly be any more wear and tear than flooring the pedal from a standstill.
    I think that the thunk from the transmission when you take out the slack could be damaging at full power. It's aways going to be the maximum amount of lash (I think that's the proper term?) as well from the proceeding drag.
    WARNING: Danger of Electric Shock! Vehicle may accelerate quicker than anticipated.
  4. #24
    Nov 2010
    Minneapolis, MN
    I spent an hour discussing these sorts of details with Eric Bendler (from Tesla service in Chicago) today. He said that when the "transmission" is in neutral, no electric fields are being induced in the rotor and when you switch the drive back on it simply starts up the magnetic fields again. There's no real "shock" to the system... rather, the computer calculates a frequency, voltage and current to apply to the motor to put it into regen mode if your foot is off the throttle, or to accelerate if your foot is on the throttle pushing it past the point where it would have been had you been coasting in drive at that exact speed (if that makes sense). He's going to go back and consult with the engineers, but he's about 100% sure that you can't hurt the car by taking it in and out of neutral no matter what you're doing with the throttle at the time. In other words, it seems that the "thunk" is a calculated one that doesn't exceed what the transmission can handle, and represents the most instantaneous and most powerful action the motor/transmission can take safely at that moment depending on the speed of the car and the position of the throttle.
  5. #25
    mod squad bonnie1194's Avatar
    Feb 2011
    Blog Entries
    4
    Quote Originally Posted by zack View Post
    That's been my worry, while reading this thread. Thanks, Zack. I'll wait to hear confirmation before trying.
  6. #26
    ERIC VFX vfx's Avatar
    Aug 2006
    Quote Originally Posted by ChadS View Post
    I agree that it would be nice to be able to turn regen on and off (better yet: dial in a level for when your foot is off the pedal). But that really just makes it easier to get top efficiency;....
    I want regen on demand. I image a steering wheel stalk (car have so many these days, why not?) that is a regen adjustment lever. Push up for less regen and down for more. Push in to turn it off quickly and push it again to go back to last setting.
  7. #27
    Feb 2011
    Blog Entries
    4
    Quote Originally Posted by bonnie1194 View Post
    I lied. Not intentionally. I tried it on the long drive back winding back through my neighborhood (which ends with stopping at my mailbox). Fun!
  8. #28
    Quote Originally Posted by vfx View Post
    You already do have regen on demand: just use your foot. It's incredibly simple to get less regen with the stock system. I found it very easy to transition from compression braking skills learned on ICE vehicles to the regen braking skills necessary to completely control the Tesla Roadster. The only thing you can't do is get more regen than the maximum the computer allows when you completely release the pedal.
  9. #29
    Getting OT for this thread, but there could be a lot of reasons for "sub-par" braking performance. But a couple notes:
    1. If you are engaging ABS - the brakes are plenty strong. Since all cars can easily engage ABS with a good stab of the pedal let's assume that the brake hardware is sufficient for now.
    2. Now that you've got the tires nearly locked up - what you really need are stickier tires. As others have already mentioned, the Roadster is a lot heavier than the Elise, but the tires are the same width. Wider tires ought to reduce braking distances significantly. The Auto-X / track guys seem to like 195 width tires in the front
    3. The other problem with "weak" brakes could be brake fade - but I didn't hear anyone complain of that so I'll assume the stock brake equipment is sufficient. Perhaps after stickier tires you'll find that brake fade is an issue - looks like there are big-brake-kits for the Elise that might fit.
    I tend to agree: The stock equipment should be more than sufficient.
    When autocross guys who aren't familiar with the Tesla see the rotors, they often say that they're incredibly large. I don't even think they're adjusting for the small size of the Roadster. Tesla even put larger hubs than the stock Elise - are you folks sure that the brake equipment is identical between the Elisa and Roadster, even though the hubs are different?
  10. #30
    Aug 2006
    Not even close. There is no "on demand" neutral. Attaining neutral on mountain roads takes a skillset that is impossible and unnecessary if it can be on a steering stalk. And no "on demand" full regen (stops a 40 miles per hour car in 12 feet)
  1. Coasting in Neutral
    By LuisV in forum Roadster
    Last Post: 10-30-2009, 06:15 AM
  2. Replies: 14
    Last Post: 09-25-2009, 03:02 PM
  3. Replies: 0
    Last Post: 01-07-2009, 04:28 PM
  4. Tropica: Blast from the Past
    By tonybelding in forum Electric Vehicles
    Last Post: 05-27-2007, 10:36 AM
  5. Neutral gear
    By WarpedOne in forum Roadster
    Last Post: 11-21-2006, 05:54 AM
