Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: Silly question....what do you use to hang the cord for the universal charger?
  1. #31
    Nov 2011
    Long Beach, CA & Taos, NM
    Quote Originally Posted by W.Petefish View Post
    Be careful with that configuration in your garage.
    Can you be more specific as to what I should be careful of or why I should be careful?
  2. #32
    Quote Originally Posted by Tesla 940 View Post
    I installed a 50 amp outlet on top of one of the garage ties. The first picture shows the power cord attached and layed out over another tie to support the weight. The cord then drops down into the center of the garage.
    Attachment 4291
    I then simply lay the cord on the four-post lift and attach it to the car.
    Attachment 4290
    Tesla940,
    could you tell me more about your car lift? How much space does it need? Cost?
    I need more car space!!!
  3. #33
    Nov 2011
    Quote Originally Posted by 7racer View Post
    Tesla940,
    It is a Bendpak. I got it about 7 years ago so I don't know what current prices are.
    When I was looking I noticed that many of the repair shops used Bendpak so that was a factor in my selection. There are many Brand Name lifts but I understand most are made in China - if that matters. Most "basic" lifts have 7,000 lb to 9,000 lb rating. That is 2 to 3 times that actual weight of the cars I store on them. The overall dimensions are all pretty much the same - a couple inches wider, longer, higher so probably not a concern. With all that said - I know some people have very strong opinions on good versus bad lifts. Do a Google search and you will find all kinds of brands and some can be twice the price of others - the higher priced ones claim USA Made - Not some China junk.
    Some "options" include drive-up ramps, drip pans, jack stands, and casters (roll the lift around - with or without a car on it). Some are included others cost more. Drip pans can be obtained at the local auto parts store for $10 and can be made to fit - another option is to purchase some plywood and cut to size - a lot cheaper than the factory available pans.
    One thing to consider - the one in the picture requires air pressure (about 20 psi) to release the safety locks. I have another brand at our other house and the safety locks are mechanically activitated (I can't remember the brand name at this time but if your interested I will be at the other house next week and can provide that information).
    Finally, assembly - The heaviest piece is about 400 lbs, the next heaviest is probably 200 lbs, all the other pieces are probably 100lbs max. I was told it takes two people to assemble. I was able to assemble the last one by myself (OK, I needed my girlfriend to help lift one of the rather light but ackward sub-assemblies). I used a rolling hydralic jack and a couple pieces of 4x4. It took me about 6 hours.
    Alot of choices in the $2,500 range.
    Hope this helps.
  4. #34
    Senior Member W.Petefish's Avatar
    Apr 2011
    North Texas (DFW)
    Make sure that the locks are in place when doing that. There have been several reports of repair shops using similar lifts and storing cars under them during severe weather. They come back in the morning to find that the lift had bled pressure off and, for lack of a better term, crushed the car under the lift.
    If it is worth doing, it is worth OVER doing. - Mythbusters
    Debunking Pseudoscience is fun!
    Arctic White Roadster 2.5 #1200, S Sig Performance Vin# 227
  1. Length of cord on universal charger (can it reach from right side of car?)
    By evinfairfax in forum Model S: Battery & Charging
    Last Post: 01-19-2013, 07:05 PM
  2. Question about the Model S charger
    By fairlycool in forum Model S: Battery & Charging
    Last Post: 01-16-2013, 02:26 PM
  3. UMC (Universal Mobile Charger) adapters
    By wiztecy in forum Roadster
    Last Post: 09-02-2012, 12:41 AM
  4. Question on Charger Location
    By rogbmw in forum Model S: Battery & Charging
    Last Post: 05-18-2012, 11:31 AM
  5. Universal Mobile Charger with 14-50 adapter $1000/obo
    By jasonhi in forum Tesla Parts for Sale
    Last Post: 05-14-2012, 09:13 AM
