"Milling Noise" or "Leaking Balloon" Sound
For the past several months, I've been hearing a whining noise as I start accelerating through 5-10 mph. I thought it was just me but over the holidays, my daughter, back from college, asked me what the noise was. I made an appointment at the Decatur, GA service center to have it looked into and to have my first annual service. When I dropped off the car, I explained the issue to them in some detail. When they called later in the day to say my care was ready, I asked them about the milling noise and they said they couldn't recreate it. When I went to pick up my car, I took one of the technicians for a ride so he could hear the noise. I was able to create the sound but the technician said that after 5000 miles it wasn't unusual for Model S to make that sort of noise. I was bit surprised by his answer. He said they sometimes record sounds and send them back to Fremont for analysis. It wasn't clear if they did that for my car. I told him I would make some recordings which I would send to my service rep which he thought might be helpful. A link to the recordings is attached. <span class="text_exposed_show" style="display: inline;">[video=vimeo;152231176]https://vimeo.com/152231176[/video]
I've looked through numerous "milling noise" and "leaking balloon" post in this group and the teslamotorsclub website and it looks like several folks ended up having to have their drive units replaced. Should I take it to another service center? Do I call HQ? Given Telsa's great reputation for excellent service, I'm at something of a loss as to what to do. Thoughts/suggestions?
Thanks, Paul
Sounds like milling to me. Ask them to take a recording and send it to HQ. The balloon squeal only happens for a few seconds on hard acceleration and is kinda fun. Milling sound is ever present, sounds like a bad electrical transformer, and is really annoying.
Definitely sounds like milling to me. As Rick says, take it back to the service center and ask that they take a recording and send it to engineering. Take the person with the recorder on a test drive and reproduce the problem for them.
I had a drive unit replaced on my May 2015 build Model S. The noise I had was louder. I had a 2013 Model S which had a balloon squeal but I liked it and never took it in, so I don't know what Tesla would have said about that. I thought it was funny as hell. But I can't hear a balloon squeal in your recording, or a milling noise. But it could be my ears or the recording.
I wouldn't worry, because if its a bad DU the noise will get worse and they'll replace it. Give it a few months.
I've had the same sound for quite a while, although it hasn't gotten that much worse in the last year. It's still there and annoying though. I tried to boost the particular sound in my recording to make it stand out more:
I'm holding out for the day when they finally have a DU version that absolutely solves this. I've seen mixed reports with the current DU revision.
I just got a call from the local service team letting me know that they want me to bring my car back in so they can take a closer to see if they can figure out the problem. I guess they must have heard something of interest in the recording. Glad they are staying on top of this.
Agree that this is the milling sound and should probably warrant a DU replacement. For clarity, it is not the leaking balloon sound, which is much more obnoxious and was fairly common on early cars. I haven't heard of any cars built in the last 2 years or so that have exhibited the leaky balloon sound.
June 2015 85D here, and I've got the leaky balloon sound on acceleration. Service center said it was battery contactor squeal and that it was normal.
Reactions: allhands
Good definition of the famous balloon squeal. All that technical mumbo jumbo, when we really know the car is just going "Wweeeee!" Because it likes to go fast too!
Although, in my car the sound seems as if it is coming from up front near dash area, not rear of car.
I don't have a D either so the front is just rolling, not pulling.
The noise I got my drivetrain replaced for is not this squeal. Had the squeal before and after the swap. Same battery pack, so makes sense.
The noise calling for a motor swap is best recreated by quick jabs at modulating to go pedal between 0 and 40kw on the orange power delivery scale, while rolling at 30mph or so. The sound pitch is proportional to pedal position and power outlay and swing of that orange arc. The loudness increases over time. Note, this sound is not proportional with rolling speed of the car. You can create the same musical variations at any speed so long as you're delivering power in that same range.. it's just easier to hear or more noticable at slower rolling speeds before wind noise and road rumble kick in to help drown it out.
1. September 2013--wonder if there isn't something newer to update this information.
2. Never read anywhere here about stator winding delaminations--probably some other public forum?
3. If contactors are vibrating then it seems to me that arcing plasma would damage the ultra-low-resistance contacts. Maybe that's what inconel damping springs are intended to solve...
edit to add patent reference: switch with damping
just my 1¢, bandwidth is half-price today.
I have a low vin (5xxx) 2013 and had a higher (21xxx) 2013 as well. My high vin car was silent however my low vin car has made a whining noise since I picked it up a couple months ago. The noise isn't obnoxious or very loud but it occurs under any throttle application and regen as well. Having not heard the milling noise, I assumed this was it. So a Tesla tech went on a ride with me and told me that it's absolutely fine. He was actually surprised that my other car made no noise at all.
This comes as a bit of a surprise to me as the first car I rented made no noise, my first high vin car made no noise and even the P85+ loaner Tesla has me in makes no noise. Nonetheless, they replaced the drive unit for me but have assured me throughout that the only reason they replaced it was because of my noise complaint. I wonder how many people are mixing the milling sound noise with regular whining and are assuming their DU is failing. Tesla's willingness to replace the drive unit for no other reason than a noise complaint might serve to back up their assumptions too.
