GM connection mentioned in the article:
https://uwaterloo.ca/stories/waterloo-researcher-leading-charge-next-generation-battery
Fair to say you are sceptical?Let's discuss this again after they produce the first 1000 kWh worth of actual, physical, batteries. Vapor batteries are always quite impressive.
ditto?Yes, indeed! I just invented a new vapor battery, in which the anode, cathode and electrolyte are all vapor! The charge rate is great, the energy density in Wh/kg is great, the only problem is that while it is very light, it's actually very large. Actually the other problem is that it's hard to solder the contacts on to it.
The article references a partnership of sorts between GM and the research being performed at Waterloo...so I'm assuming GM has first dibs. Does anyone have more info?I don't see why it would only benefit GM. Tesla has started using silicon in their 90kWh battery. Silicon anodes are typically plagued by short lifespan. If their research actually materializes as a viable product, I assume it would help Tesla, or anyone else, using silicon in the anode.
I like this theory.Enquiring minds want to know if this silicon anode technology is part of the LG Chem cells that will starting being made next year for the Chevy Bolt and other "200-mile" cars. That could explain how they are managing to tuck ~60 kWh into a smaller car without using the Tesla/Panasonic NCA chemistry. I think that article about the Waterloo work also suggests that it could see commercial use as soon as next year.... Any licensing preferences that GM may or may not have from assisting on this work could also be part of the explanation for why GM is only paying $145 per kWh when other LG customers are apparently paying more.
Or not.
Also, It is patented...and it's not clear by who. So the announcement may help some companies...and not others.I don't see why it would only benefit GM. Tesla has started using silicon in their 90kWh battery. Silicon anodes are typically plagued by short lifespan. If their research actually materializes as a viable product, I assume it would help Tesla, or anyone else, using silicon in the anode.
From what I've read because silicon expands massively when it absorbs lithium ions (actually it can't be the silicon atoms, it must be the crystalline structure), anodes with high levels of silicon have a short life expectancy. The Panasonic batteries with some silicon have about as much as they can handle before the anodes start getting fragile. It may be possible to come up with an anode the is flexible enough to expand and contract many thousands of times before failure. But like many in this thread have said, I want to see it working in the real world first. I also want to see it working for some period of time. A battery that can only be charged a few times before failure isn't very useful for a frequent charging application.
If you want to be pedantic, batteries existed long before the internal combustion engine. They even predate railroads.Consider that the battery has been around about the same time as the internal combustion engine.
