Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: HEADS-UP: Simultaneously Charging a Tesla and a LEAF
  1. #11
    Senior Member Lloyd's Avatar
    Jan 2011
    San Luis Obispo, CA
    S-2000
    Leave the wire, you can always have larger, but you need a 50 amp breaker as the recipticle will only take 50 amps. If you upgrade later to an HPC or other reciptacle then the wires will be in place.
    SP-2823 XP-12
  2. #12
    Junior Member
    Oct 2010
    Columbia, MO
    Quote Originally Posted by Jaff View Post
    ...so a Leaf moves in, and there goes the neighbourhood?...
    It could be worse...don't get near a Chevy Volt (plugged in or not)
    http://www.dailymail.co.uk/news/arti...cond-week.html
  3. #13
    Senior Member Jaff's Avatar
    Aug 2010
    Grimsby, Canada
    Let's hope it wasn't the Volt nor the conversion...bad press for EV's either way...
    Roadster # 1137 / Model S # 2120
  4. #14
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    What are the odds that the ICE component started the fire...?
  5. #15
    Quote Originally Posted by Lloyd View Post
    Good advice! I didn't think about that. Easy to change since I've already purchased the 50A breaker.
    I disagree on this one. The HPC wires directly in without a receptacle, and I would need a new conduit for the HPC anyway. I'm planning on taking out the 70A wire just because it's so thick that it's in the way. Things will fit much nicer with the 55A wire, and I've already purchased it. The 70A wire wouldn't be good enough for the HPC anyway, since I'd need 90A wire for that. 70A (or 72A?) is the load on the 90A breaker.
    1990 Honda CRX Si - Barbados Yellow
    1998 AM General HMCO - Competition Yellow
    2000 Honda S-2000 - Berlina Black
    2011 Tesla Roadster 2.5 - Very Orange
  6. #16
    If anyone cares, I did downgrade to a 50 A breaker and 55 A wire. I though the smaller gauge wire would be easier to work with than the 70 A, but it was still a pain!
    P.S. I verified that the neutral wire is not used by the Tesla UMC, but the Safety Ground is most certainly connected. I still wired the neutral to my house in case I ever plug anything else in to that receptacle.
  7. #17
    Quote Originally Posted by William3 View Post
    Any updates on this issue of charging both cars at the same time?
    Yes ... Nissan determined that better filtering is in order and started updating the charger in the LEAF. However, I am not privy to details (like starting with which VIN). A particular LEAF owner who also happens to charge where a Tesla Roadster 1.5 charges at the same location has had the LEAF updated via a warranty service at the Nissan dealer. That solved the issue.
    My guess: LEAF VINs after probably 2,000 should be ok, but no guarantees. If you have a 1.5 Roadster charging off the same electrical service (sometimes hard to determine -- separated circuits are *NOT* sufficient isolation) as an early (<2000 VIN) LEAF ... I would pay close attention if it is unavoidable to charge simultaneosly. Again, the VIN cut off is a (conservative) guess ... I don't know if Nissan can be prodded to release that info. And then there's the uncertainty of older VINs getting updated.
    Some folks I've talked to think this issue is being overblown. Ok ... but if it was my $100k car ... I'd want to be very conservative.
  8. #18
    Senior Member daniel's Avatar
    May 2009
    Spokane, WA
    Blog Entries
    Now I'm more glad than ever that Nissan botched my order so that I was unable to get a Leaf. And especially glad that I didn't get a Volt, which I would have done had it been available two years ago. I guess GM has a new strategy for trying to kill EVs.
  9. #19
    Junior Member
    Feb 2011
    Hillsboro, Oregon, USA
    Quote Originally Posted by ChargeIt! View Post
    Nissan does have a line filter installed right before the actual charger unit in the vehicle. I have VIN 568 and have no measurable line noise and have never tripped a GFCI. One thing I have noticed is that some owners that have reported random issues have also report low line voltage. One LEAF owner also has reported that the car will attempt to draw more amperage in the event of a voltage sag. I'm not sure if that could be related, but my home runs just above nominal voltage (244/122 volts to the outlets).
  10. #20
    Model S - U.S. P - #1649
    Jul 2011
    Cheney, WA (near Spokane)
    Quote Originally Posted by DarkStar View Post
    Wow, is that ever brilliant (I'm being sarcastic in case you didn't guess)? The circuit is already overloaded, so you try to load it more.
  1. Nissan Leaf Nismo RC vs Tesla Roadster
    By widodh in forum Video
    Last Post: 09-18-2012, 06:28 PM
  2. Leaf vs 40kW Tesla race.
    By richkae in forum Model S: Battery & Charging
    Last Post: 12-22-2011, 01:47 PM
  3. Heads Up Display
    By benraemon in forum Model S
    Last Post: 11-11-2011, 06:09 PM
  4. Nissan Leaf Charging
    By Kevin Sharpe in forum Electric Vehicles
    Last Post: 12-03-2010, 09:36 AM
  5. Replies: 10
    Last Post: 04-24-2010, 10:59 AM
