Cost comparison
Patrick W
1,524
943
SLC, UT
I'm trying to compare the cost of "fuel" to drive my S vs my ICE. Anyone here care to check my figures?
My ICE gets 27 MPG.
Gasoline currently costs $2.96 per gallon (a bargain compared to the rest of the world).
The display on my S says I have driven 4,090 miles since resetting the counter and that during that time I used 1,136 kwh.
With electricity currently costing $0.088854 per kwh I spent $100.93 to power the S.
If I had driven the same distance in my ICE I would have burned 151.5 gallons of gasoline costing $448.40.
So about $101 in "fuel" for the S and about $450 in fuel for the ICE.
Does that look right?
Thanks!
Unless you've measured the 1136 kWh at the wall, your numbers are probably a little light.
Your actual usage was likely around 15% higher than that (so 1306 kWh), due to charging losses and vampire drain.
That would mean $116 instead of $101.
Not a huge difference though.
My ICE gets 27 MPG.
Thanks!
You used about 8% - 10% more AC electricity than the battery received in DC. Did you measure kWh usage at a dedicated power meter, or calculate from battery metrics?
Ah, had not thought of that. But even with that I'm guessing I actually spent well under $100 as a lot of what I used came from super chargers.
Markup vs. markdown effect.
18% loss in efficiency, marked up becomes 22% "higher than expected".
Bingo! Great point, makes perfect sense when you run the numbers. His efficiency was 81.4%; consumption was 728, actual meter usage was 894. But if you extrapolated the cost (I know he paid $0.24 per other blog posts, no TOU plan available in MA), the consumption appears to have cost $174.72 when in fact it was $214.56, or 22.8% higher.
Or put another way, 100 / 81.4 = 122.8% :)
