Page 29 of 35 FirstFirst ... 19252627282930313233 ... LastLast
Results 281 to 290 of 342
Thread: PEM, motor gets too hot -- fans failed
  1. #281
    Senior Member JRP3's Avatar
    Aug 2007
    Central New York
    19 amps at 12 volts for 312 CFM seems pretty high. I've got a Procomp radiator fan rated at 500 CFM that pulls about 5 amps at 12v. Maybe because it's pushing through restricted passages?
  2. #282
    Sig 100 - #52 frequencydip's Avatar
    Dec 2011
    Los Angeles
    Quote Originally Posted by JRP3 View Post
    I think your comparing a Centrifugal fan to a Propeller Fan. propeller fans are more efficient at low pressure.
  3. #283
    Senior Member smorgasbord's Avatar
    Jun 2011
    SF Bay Area
    Picked my car up today. Didn't overheat, but it wasn't that warm out and didn't take my usual route. Temp was on the last blue bar, though.
    One thing they did was to remove the "sump cover" This is a plate the covers the area that had leaves in the photo I posted earlier (here). They want me to monitor the temps and report back to them. I was thinking that area was where the hose from the blower attached to the PEM, but apparently not. Wish I could have been there when they removed the PEM.
  4. #284
    ?? So who took that photo of the leaves blocking the vent??
  5. #285
    #421 Model S #S32 Eberhard's Avatar
    Oct 2010
    Germany
    Quote Originally Posted by vfx View Post
    What is that?
    This is the heat exchanger for the charger. if blocked, you cannot charge at higher rates. mine got stepped down to 27A/44A instead of 60A. Also the fan worked at highest level without getting a proper result.
    #421 S32 P85+
  6. #286
    Quote Originally Posted by Eberhard View Post
    I had a Roadster stop at my house for some juice yesterday. I've got 70A but his VDS kept dropping to 53A/53A while his PEM felt very warm. It was a bit of a mystery to us but now I think he's got leaves blocking his airflow. I should have looked at his PEM temp on the VDS but didn't think of it. He's got a 2.5 with the new fan.
  7. #287
    Scottish chap mgemmell's Avatar
    Jan 2012
    Madrid, Spain
    Quote Originally Posted by hcsharp View Post
    Mine is also blocked I think (as does the ranger). They should be coming out to clean it and upgrade the fan next week. However, we did a 1100km round trip this weekend to Coimbra (Portugal) from home (Madrid) and the biggest issue we had was when charging yesterday at 32A... It was a hot day (officially 39C) and in the midday charging place OVMS showed the external temp to be 53C!! This made keeping PEM and Battery cool very difficult and the charge current got restricted down to 10A.
    As this was going to turn a 6 hour recharge into an 18 hour recharge we came up with a solution (Don't try this at home folks... water and electricity do not mix... but it did work for us)... PEM ice cooling.
    We put *sealed*bags of ice on top of the PEM and waited to see what happened (we also put some snacks on top of the ice to cool them too):
    Name:  PEM liquid cooling.JPG
    While I wouldn't want to put bags of ice on the PEM regularly, on this occasion it worked and we charged at 32A after about 30 mins with the ice packs.
    Of course the Model S has this problem covered. Maybe one day one of us will come up with a liquid cooling upgrade for PEM and motor...
    Roadster VIN#454EU
    ModelS Signature #92
    Renault Zoe #87
  8. #288
    Senior Member W.Petefish's Avatar
    Apr 2011
    North Texas (DFW)
    I think that upgrade might be coming from TM itself.
    If it is worth doing, it is worth OVER doing. - Mythbusters
    Debunking Pseudoscience is fun!
    Arctic White Roadster 2.5 #1200, S Sig Performance Vin# 227
  9. #289
    Roadster #1144 + Sig 114 dsm363's Avatar
    May 2009
    Texas
    How big of a gesture would that be to replace all the PEMs on the Roadster for free with a liquid cooled one. Won't happen since its expensive.
  10. #290
    Head Moderator / Administrator doug's Avatar
    Nov 2006
    Stanford, California
    Blog Entries
    Quote Originally Posted by mgemmell View Post
    I suppose there's a chance doing this could cause condensation inside the enclosure.
  1. PEM Temp Readings
    By Aspirant in forum Technical Discussion
    Last Post: 07-17-2012, 11:41 PM
  2. Universal Mobile Connector - failed
    By harbthom in forum Roadster
    Last Post: 07-11-2012, 11:47 AM
  3. PEM Failure
    By tdevince in forum Technical Discussion
    Last Post: 07-03-2012, 12:09 PM
  4. Take THAT, Tesla fans!
    By dpeilow in forum Off Topic
    Last Post: 10-28-2008, 08:05 AM
