Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Compass and Elevation
  1. #21
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    Older GPS receivers had a limited number of channels, 4 or 5 typically. Modern ones have a lot more (at least the decent ones, I suppose). There's a little bit of information on this on Wikipedia.
  2. #22
    Head Moderator / Administrator doug's Avatar
    Nov 2006
    Stanford, California
    Blog Entries
    Quote Originally Posted by NigelM View Post
    Altimeter - Wikipedia, the free encyclopedia ....GPS may be unavailable, for example....or may give wildly inaccurate altitudes when all available satellites are near the horizon...]
    Huh? That makes no sense as GPS satellites are in geostationary orbit. Your GPS doesn't stop working at night....The perils of Wikipedia!
    I stand corrected! And also slightly dizzy from watching that graphic flying round.... Although I think it also proves my point as your graphic never shows less than 7 satellites visible at any one time.
    I think you should just read up on how GPS works. All the sats near the horizon presents a geometry issue (all within the same plane) that further reduces vertical accuracy. The problem is not that the sats are setting over the horizon, as your posts seem to imply (or refute, rather).
  3. #23
    Administrator dpeilow's Avatar
    May 2008
    Winchester, UK
    There are also signal propagation issues that get worse as the signal has to travel through more of the atmosphere (i.e. low down). This will be improved as the new systems use more frequencies, allowing receivers to compare how each signal on a wider range of frequencies was affected and correcting errors more accurately than is currently possible.
    But yeah, while 7+ sats are possible to see - and I have done many times - often hills or buildings will mean you only see 3 or 4. I've seen receivers that claim to be able to track 21 satellites, which is somewhat pointless.
  4. #24
    R #1211, SSL#282, XS#313 NigelM's Avatar
    Apr 2011
    Sarasota, FL
    Quote Originally Posted by doug View Post
    I'm not that motivated (or that smart? Nobody answer!), but thankfully there are plenty of people on here who know more about this than me. I just wondered if the Roadster elevation display was fixed in 100ft increments.
    PLEASE NOTE: Posts are the copyrighted intellectual property of the author, and are intended as part of a conversation within this forum. My words may NOT be quoted outside this forum, without my expressed consent.
    Moderator: Model S, TSLA Investor Discussions, Florida and Off Topic forums
  5. #25
    ERIC VFX vfx's Avatar
    Aug 2006
    (Now also curious if you found out what your problem was Eric?)
    Was a bad GPS unit.
  6. #26
    2.5 2011#1263 "NO GAZZZ" DZCPA's Avatar
    Jan 2011
    San Clemente, CA
    My Roadster does move in increments of 100 feet .
  7. #27
    Senior Member W.Petefish's Avatar
    Apr 2011
    North Texas (DFW)
    There is Enhanced GPS as well as DGPS. Using cellular towers along with GPS to determine exact positions within 3 feet is how Enhanced GPS works. DGPS uses dedicated radio towers and a dedicated receiver. DGPS is by far less common now because of it was phased-out by the advent of Enhanced GPS.
    In short your best bet for positioning is your iPhone/Android Phone. (at least in an urban setting) Out in the country your best bet is your handheld Garmin or Magellan.
    If it is worth doing, it is worth OVER doing. - Mythbusters
    Debunking Pseudoscience is fun!
    Arctic White Roadster 2.5 #1200, S Sig Performance Vin# 227
  8. #28
    Apr 2011
    Sarasota, FL
    Quote Originally Posted by dpeilow View Post
    Although now I have learnt more about GPS than I ever needed to know, I spent this morning driving round with the GPS satellite display on the e-dashboard. My Roadster tracks 11 satellites and always locked on 9 of them. Which 9 from 11 varied but it never changed from 9; all my driving was within a 20 mile radius. The most interesting thing is that my Roadster elevation stayed on 0ft the whole time while the GPS altitude showed anything from 65-113ft over what was pretty flat territory. (From previous explanations, now I know why). BTW: At home now my driveway is 11ft above sea level but the GPS altitude shows it as being 65ft.
    I wonder why Tesla included the elevation readout on the VDS? Does it serve a purpose for anyone that I am too dumb to figure out living at sea-level?
  9. #29
    Nov 2006
    Blog Entries
    Because it costs energy to climb hills...
    For a car without combustion, absolute elevation is not as important as the differential.
  10. #30
    Aug 2006
    I have two charge points about 150 feet apart. The car knows the different settings for each spot.
  1. Elevation Change vs. Range
    By NuclearPowered in forum Model S: Battery & Charging
    Last Post: 07-14-2012, 10:21 PM
  2. Political compass test
    By JRP3 in forum Off Topic
    Last Post: 04-22-2012, 08:41 PM
  3. Political compass test
    By JRP3 in forum Electric Vehicles
    Last Post: 04-17-2012, 10:23 AM
