Page 3 of 15 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 142
Thread: Wireless Charging
  1. #21
    They must have defeated the mechanism that stops the car driving with the charge port door open. Personally I'd prefer a robot arm that opens the door and plugs in a conductive charger. I could see that working. And no loss of efficiency.
  2. #22
    Roadster #1144 + Sig 114 dsm363's Avatar
    May 2009
    Texas
    I don't get it. What's the point of routing the cable like that?
  3. #23
    Roadster 919, S 2006 Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    Anti-theft, I assume.
  4. #24
    Head Moderator / Administrator doug's Avatar
    Nov 2006
    Stanford, California
    Blog Entries
    Fulton Innovation blows our minds with eCoupled wireless Tesla, inductive cereal boxes - Engadget
    ... The model on display here is an obvious retrofit, a coil stuck between the front wheels that runs to an AC/DC converter and then, quite inelegantly, to a cable running out a vent and into the input on the car itself. This is an obvious retrofit but it was done with purpose: to show that without modifying the internal systems of the car wireless charging can be done -- and reasonably efficiently, too.
    This form of charging is 80 percent efficient, but the company estimates that with a more integrated system (mainly deleting the converter) they could get to 89 percent efficiency. The wired charger? It clocks in at 96 percent efficiency, meaning for any given voltage the charging time would only be about 7 seven percent slower going wireless -- a potentially small price to pay for the ability to turn an entire parking lot into a charging station without having to worry about wires or vandalism or semi-inadvertent electrocution of curious people who decide to see what happens when terminals get licked....
  5. #25
    Administrator dpeilow's Avatar
    May 2008
    Winchester, UK
    Cool - but no one with a pacemaker could go in there
  6. #26
    Apr 2010
    Ottawa, Canada
    Blog Entries
    I know you're joking, but there's little chance of the field affecting pacemakers. These systems would use quite low frequencies. In fact, they'd probably run below 9kHz to avoid having to be FCC certified as an intentional radiator.
    At least this explains the weird plug installation...
  7. #27
    May 2008
    Winchester, UK
    They should've got Tomsax to do the plug mod. Much neater.
  8. #28
    ERIC VFX vfx's Avatar
    Aug 2006
    The 140 mile misquote of Tesla's 240 range removes a bit of credibility.
    The idea of these being good for high crime areas is good but this would be equally cool in front of a high end restaurant or hotel parking spots as well.
  9. #29
    Nov 2006
    Blog Entries
    Quote Originally Posted by vfx View Post
    That's a simple error. What removes more credibility is the "able to charge in the same amount of time as if it were plugged in" quote (repeated by Engadget), which is deliberately misleading.
  10. #30
    Aug 2006
    Quote Originally Posted by doug View Post
    Good point.
    It does look cool though.
  1. Replies: 51
    Last Post: 06-13-2012, 05:16 PM
  2. Wireless charging in Model X?
    By jfeister in forum Model X
    Last Post: 01-25-2012, 09:11 AM
  3. Wireless Charging
    By Doug_G in forum Technical
    Last Post: 04-07-2011, 12:29 PM
  4. RangerEV wireless diagnostic
    By TEG in forum Electric Vehicles
    Last Post: 04-30-2009, 08:20 AM
  5. Nissan Wireless recharge?
    By malcolm in forum Electric Vehicles
    Last Post: 11-16-2008, 11:06 AM
Tags for this Thread
