I complained about continuous HVAC Compressor Over Temp messages during charging - multiple warnings every night - in the log for two years, and was told it was normal.
Then I had the HVAC upgrade, where they replace the front radiator assembly. They had to recharge my freon. The Ranger said that one of the gadgets tends to freeze up during the charge process, and he was worried it had happened. So he checked my logs remotely and came back that evening and did it again. This time it worked properly and not only did the air conditioner work MUCH better, I never saw another one of those messages in the log.
So, no it is NOT normal, even if they tell you it is. And they often under-charged the freon at the factory, no doubt due to the "gadget freezing up" problem (he didn't say what the gadget did).
