My questions are:
1) What amperage does the Tesla pull when using a 110/120V outlet? Is there any configuration available (e.g. With our Volt, we can select 8 or 12 Amps)?
2) Is there a record kept that I can access online or via smartphone as to the history of my charging sessions on 110/120v? (e.g. Start time, stop time, kWhs pulled)? Is that data downloadable in a format like CSV?
3) If the Tesla is garaged in a relatively stable temperature setting of 50-70 degrees, how many mph can I safely assume the Tesla would add when using 110/120V charging? In other words, if I charge the Tesla on 110/120v for 8 hours, how much range would that add (I know there is some loss to the active battery management system and that is what I'm seeking to understand)?
1) The car will pull 80% of the maximum circuit capacity. Circuit breakers are designed to permit surges, but not constant operation at 100%. You can select less amperage be pulled (not more) as it's locked out at 80%. Charging off of 110/120 @ 15 or 20 Amps is pretty slow. Keep in mind, preheating or precooling the car will almost terminate all charging activity due to the limited circuit capacity.
2) If you have the App, it will allow you to start and stop charging and monitor the current draw as well as estimated time of completion. If you have an iPhone (not at Android as I've read on the forum), it will alert (audibly and visually) that the car has started/stopped charging.
3) There used to be a table that would show charging (in miles per hour) on the Tesla website, however, I can't find it at this time. You can search this forum as there are some very nice reader contributed lists that show the charging statistics for all levels of voltages and amperage. If I remember correctly, you can expect 5 miles per hour for a 120 @ 15 amps and 6 miles per hour for 120 @ 20 amps. If the battery is kept at a convenient temperature (the 50-70 certainly sounds right), active battery temperature management shouldn't come into play that much.
Here in New England, I've noticed on the car will become "cold soaked" and therefore require a heating of the battery with no charging happening until that cycle is completed. This can range from 15-20 mins to almost an hour with the current draw being 48A. I'm on a 60A 220V circuit and I usually get around the mid 30's in miles per hour of charge when the battery is at a "happy" temperature.
There are several methods of thought regarding using "local" superchargers (assuming you've paid for the supercharging option). Some believe that you've paid for it therefore you should be able to use it no matter where you are (even if it's in your backyard). Others believe it is for traveling only and you should not use your local charger (say at a nearby mall). Tesla does not appear to have a policy either way on use of superchargers. This is for you to determine right vs. wrong. My belief is that if you NEED them use them. Remember, there these are your gas stations. If I were to travel extensively in a day and deplete my range I would plug in at home. Say it were to become necessary to travel later in the day with less mileage than I was planning on driving. The supercharger certainly would be convenient for a quick "top off" to insure I make it back home.
Something else I've noticed myself doing is becoming a patron of those locations with charging stations. I'm right in the middle of two pretty good size malls/shopping centers. One does not have any charging capability and other does. The one that does not is easier to drive around and less busy. I've noticed myself preferring to travel to the one that does have charging facilities more often (depending on what I'm looking for). After all, mall management realizes that it's an attraction to those of us who have "gone green". BTW, as a side note, PlugShare can be your friend as well.
All in all, it's truly the most fun ride going! Anywhere! Ever! Just have a backup plan in the event that you're lacking sufficient charge...
