Note: Updates near bottom of this post.
I had originally posted this info/pics in my thread about my off-grid solar project (broken link, see updates), so, I apologize to the mods for duplicating the info here, but I think it deserves it's own thread in the appropriate section as well. I figure no one would really find it buried in a somewhat unrelated thread.
Long story short I purchased an 85 kWh pack from a salvaged Model S for use in a non-EV project (off-grid solar). That aside, I finally got it to where I wanted it yesterday and began working on it. Since I have no way to figure out the low voltage signalling, I had to remove the cover from the pack to get some insight into how I could utilize it.
Unfortunately the pack has been sitting for a while (over a month) without being connected to a vehicle. As you can see from the images below the pack voltage is sitting at 313.8V, which is well below where the Model S would drain the pack. However, it's not a lost cause... I doubt one deep discharge will be harmful for my purpose. This comes out to something like 3.2V per cell still, which isn't all that scary yet. I am working on a charging solution.
The pack is built like a tank. It appears to be very well thought out and designed very nicely. It is heavy and the framework is very strong.
Images I post in this thread and my related commentary are posted and published by me, the original photographer. All copyrights and all other rights reserved. These images may not be copied or otherwise distributed without my express permission.
All of that said, here are some images with the hopes that people find them informative:
Pack right after it came off of the truck. (Yes, I bolted some wheels to it)
85 kWh "D" Pack
Plastic cover which I later discover has the pack main fuse under it.
Label on the center of the pack.
Top view of the high voltage connector
Pack after removing the plastic cover which what appears to be some type of fireproofing material under it (between the plastic and pack).
The two dents were where some hooks on chains were when the pack was being lowered to the ground by the transport truck. The actual modules are further down under this piece and not affected.
Removed all screws from the top of the pack and starting to peel away the top cover. The thing is held on with so much adhesive/sealant that it took us nearly 40 minutes to get to this point.
Making progress opening the pack, first couple of modules now visible. I popped a few of the orange HV caps from the one module because I was anxious to get an idea of the pack voltage and module voltage since the pack had been sitting for a while.
Top view of the one module.
Put a volt meter on the hot side of the main contactors to read the full pack voltage. 313.8V. So, not toast but definitely dead. (No comments about my cavalier method for testing this please, I know what I'm doing... most of the time)
Module voltage.
Close up of the pack's main fuse.
Got the security screws out of the front portion of the pack and removed the metal cover finally, revealing the two front modules which are stacked.
View of the front two modules showing the coolant loop quick disconnects. Those are spring loaded and the coolant actually seems to be under pressure. I may work on a way to connect to that to hook up a small radiator and pump later.
Pack with the entire top cover removed safely, over 2 hours after starting. (Yes, I bolted some wheels to the sides of the pack, and they work...)
Close up of some of the cell level fusing. Awesome safety feature here.
Another shot of the coolant loop connections and front modules.
View of most of the pack.
Main contactors. One is for positive and one is for negative. They are connected with bus bars to the pack and to the external connector. There are also small leads (visible on the top) from both sides of the contactors that go to what I would call the main BMS board.
View of part of the high voltage bus bars.
External low voltage connectors, presumable for BMS communication and pack control.
Close up view of the external HV connector showing part of the actual connection that makes contact with the large male blade connector on the car. This configuration would likely have very low resistance since it would make uniform contact across the entire connection.
Update #1:
Close up of some more cells showing the cell level fuses and the inversion of the next group of cells.
Pack's main fuse, removed.
One of the pack's contactors. This one is for the negative terminal. The other is for the positive terminal (not shown) and is a different part number.
Bottom of the negative contactor showing manufacture as "Tyco Electronics."
Tesla's part number label for the negative side contactor.
Update #2:
Front of BMS Module board (one of these on each of the 16 modules)
Back of the BMS Module board.
Note: click images for higher resolution
More pics here from full tear down phase! (Edit: Link broken due to forum upgrades)
The dang thing is HEAVY. We used several dollies with high weight ratings, chains, rope, a winch, and a few other crazy things to move it, and it took the three of us pushing in unison to get the thing to budge. I did mount some wheels to the sides to try and move it that way, and it worked OK, but I need a way to mount them better.
Also... don't try this yourself if you have never done anything with high voltage. It's definitely dangerous and I do not suggest it.
My project is not endorsed or condoned by Tesla. Everything I'm doing I'm sure is frowned upon by them and I am doing so at my own risk and hold Tesla harmless with regard to my project. If something bad happens as a result of me messing with this battery pack it has nothing to do with Tesla.
I figured someone would find these pics and comments interesting and/or informative. I will try to take some more as I get to actually doing something with the pack.
-wk
Update 2014-09-10 --- Added scans of BMS board from a module.
Update 2014-09-11 --- Added link to new post with more pics (so not to make this page impossible to load...) (Edit: Link broken due to forum upgrades)
Update 2014-12-16 --- Second pack tear down (Edit: Link broken due to forum upgrades) with time lapse video of the tear down
Update 2015-02-14 --- Weighed a module in my other thread: Plan: Off grid solar with a Model S battery pack at the heart - Page 19 (Edit: Link broken due to forum upgrades)
Update 2015-03-28 --- Added some pics of tear down of a module - Pics/Info: Inside the battery pack - Page 50 (Edit: Link broken due to forum upgrades)
Update 2015-04-10 --- Added single cell discharge curve - Pics/Info: Inside the battery pack - Page 55 (Edit: Link broken due to forum upgrades)
Update --- At some point all of the links above were broken due to forum changes. I don't know the exact posts these referenced, so can not easily correct them. Also, at some point my externally hosted images were illegally copied to and hosted on the forum itself without my permission. I've corrected this for this post, and if this edit is undone there will be a copyright lawsuit. TMC was NEVER given permission or license to HOST and redistribute my copyrighted images. This seems to have been done with other images in posts I can no longer edit to correct as well, and I'll be looking into getting this corrected.
85 kWh "D" Pack
Module voltage.
Update #1:
Update #2:
-wk
