Following up on this thread: Tent Camping in a Model S
The poster references using heavy bags to keep the climate control on through the night. What is the control flow for deciding when to turn on/off the HVAC? I thought if you put the car in neutral, set the e-brake, and left it "running" that it would run indefinitely. Is this true?
Or is there another method that allows the HVAC to run indefinitely that is more efficient in terms of power usage? (i.e. "leaves less other stuff turned on")
