Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: Direct Methanol Fuel Cells
  1. #31
    EU Model S P-37 VolkerP's Avatar
    Jul 2011
    Germany
    DMFC from oorja as explained by CEO:
    1500W
    3 gal Methanol tank
    12-16 hours of continuous operation
    estimate of fuel costs: less than $2 per gallon
    refill in <1min
    more specs on the web site: Oorja Protonics - Enabling Power
    About Oorja Protonics
    Founded in 2005, Oorja Protonics is the leader in providing reliable and economical liquid fuel
    cells for the material handling industry. By leveraging its breakthrough technologies, Oorja
    manufactures the most efficient and powerful portable liquid Fuel cells that significantly
    reduce operating costs and green house gas emissions.
    The company is headquartered in Fremont, CA.
    Let's fit 2 of them (each at 170lbs) in the frunk and drive the Model S with 40kWh pack at 55mph drive, which takes ~3hours. The fuel cells would produce 9kWh in that time, which give another 36 miles or 22% range extension. Not worth the hassle yet .
  2. #32
    Head Moderator / Administrator doug's Avatar
    Nov 2006
    Stanford, California
    Blog Entries
    For a practical range extender, the power output needs to be the average power the car needs to keep moving. The battery takes up the slack. You do get into some trouble if you have a prolonged high power usage situation, such as hill climbing or high speed, where you exhaust your battery buffer.
    I'd say the constant power output at 55 mph is a good benchmark. So lets look at the Model S.
    From the graph, lets say the Model S uses 260 Wh/mile at 55 mile/h. That would mean the power output would be 260 * 55 W = 14.3 kW. Ooja needs an improvement by about a factor of ten.
  3. #33
    Jul 2011
    Germany
    Quote Originally Posted by doug View Post
    That would not be range extending but a 100% fuel cell driven car with a small battery for buffering purposes. If you have a sufficiently large battery, the fuel cell can continue to fill the battery while you take a break from driving or after you arrange at your destination. I would be fine with a range extender that provides some 80% of energy needed at 75mph, as this is my average traveling speed even on the German Autobahn, drawing the rest from the battery for a 3hour driving period.
    Agree, but a system of >300lbs cannot be added without pains. I imagine a user-swappable "power brick" with suitcase form factor, weight <80lbs, and some methanol fuel cans. But it looks like this will stay a dream for the next years.
  4. #34
    Nov 2006
    Blog Entries
    Quote Originally Posted by VolkerP View Post
    No. The range extender really needs at least enough power output for average power requirements. Otherwise it doesn't actually extend your range much. The range extender has to sustain some minimum the charge buffer. The larger your battery, the more electric-only range you get in a "charge depleting mode" as GM calls it.
    That's not really the goal of a range extender. If that were the case, you might as well charge from an outlet at 20 kW or even 90 kW (Tesla's supercharger) which is much faster than the 15 kW I suggested.
    Well lets do the same math I did above. From the graph, the power usage of the Model S at 75mph is about 370 Wh/m * 75 m/h ~= 28 kW
    80% of that is about 22 kW.
  5. #35
    Model S VIN P01536 Robert.Boston's Avatar
    Oct 2011
    Boston MA, USA
    I don't quite agree with the absolute "this high or nothing" approach you're proposing, @doug. Any fuel cell will add some range, and @VolkerP makes the valid argument that the fuel cell can continue to operate even when the car isn't being driven, effectively making the vehicle self-charging. The question really boils down to, what rate of "trickle charge" from the fuel cell is meaningful? I agree with @VolkerP's math, that the extra bump isn't worth the hassle and cost. But with a better fuel cell, sure: if we could get 10kW of fuel cell generation, that would add about 25kWh of power during the time it takes to discharge the 60kWh pack at highway speeds, equaling the power available from the 85kWh pack.
  6. #36
    Quote Originally Posted by Robert.Boston View Post
    Assuming that current regen is capped at some "practical maximum" (effective but limited to protect the battery), then you wouldn't want the fuel cell trickle charging while regen is underway. Thus, it might be somewhat complicated, but you'd only want the trickle charge when not regenning. One simple algorithm would be "only when the vehicle is idle".
    I dub it "idle regen". Do any cars -- even prototypes -- exist that "increase range" while sitting idle and not plugged in (beyond the apparently trivial solar contribution on some)?
    Truly Electric Spaceship-Like Adventure ~ Signature Model Spaceship
    PLEASE NOTE: these musings are the copyrighted intellectual property of the author, and are intended as part of a conversation among the Tesla Motors Clubs membership. My words may not be quoted by any third party outside the Tesla Motors Clubs forums, without my expressed consent. Especially the NYT, which is clearly ethically challenged.
  7. #37
    #421 Model S #S32 Eberhard's Avatar
    Oct 2010
    Germany
    I like the idea, but would prefer first, to use the wast heat from the fuel cell to heat the car while cold outside and secondt overcome the range anxiety. Wait one hour to recharge and then drive slowly to the next charging station.
    #421 S32
  8. #38
    Nov 2006
    Blog Entries
    I guess it depends on how you define "range extender". You're right that it doesn't have to be "this high or none" to provide some benefit. But if the power output is not high enough you essentially remove what I think is the main purpose of a range extender (under the current expectation of the term), which is quick refuel time enabling you to drive as far as you want. Meaning the car essentially turns from an EV into a hybrid (or a "100% fuel cell driven car with a small battery for buffering purposes" as Volker put it).
    So what you're talking about is a more limited range extender. While you get more range than you'd get with the energy capacity of the battery alone, once that battery is depleted you still have to stop and wait for a recharge, even if you have fuel left in the range extender's tank. There's still some benefit to that, depending on cost. (I think Tesla has a patent on a similar concept but with mixing different types of batteries. ) Though, I don't think the goal should be the generator/fuel cell charging the battery. That energy is better used going directly to the motor, displacing energy that would have come out of the battery.
  9. #39
    Oct 2011
    Boston MA, USA
    Good point.
  10. #40
    Administrator dpeilow's Avatar
    May 2008
    Winchester, UK
    I could be wrong, but from what I read it seams like the Robert Boston / VolkerP idea is what BMW is planning with the i3 range extender, albeit a small petrol engine. And it's definitely what Audi did with that A1 test fleet with the small wankel engines.
  1. More cells than a Model S
    By JRP3 in forum Battery Discussion
    Last Post: 07-31-2012, 07:54 AM
  2. Panasonic cells for Model S
    By Eberhard in forum Model S: Battery & Charging
    Last Post: 03-19-2011, 10:59 AM
  3. Home CHP fuel cells
    By dpeilow in forum Energy, Environment, and Policy
    Last Post: 03-16-2010, 01:03 AM
  4. "Direct carbon" fuel cells
    By doug in forum Energy, Environment, and Policy
    Last Post: 02-02-2010, 06:41 PM
  5. cells versus batteries
    By TEG in forum Off Topic
    Last Post: 05-15-2009, 08:19 PM
