Page 4 of 15 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 144
Thread: Charging the Roadster - EU Style
  1. #31
    Administrator dpeilow's Avatar
    May 2008
    Winchester, UK
    Thing is, the Roadster doesn't do 400V. So your idea could get expensive.
    Furthermore, the transformer in your link is *only* single phase.
    I looked at 'converter' prices, but there was no advantage over a UPS. Must be economies of scale.
    Efficiency of a double conversion device is high 90s.
  2. #32
    May 2008
    Winchester, UK
    OK, I found another supplier of converters:
    http://www.effekta.co.uk/Downloads/E...20Pamphlet.pdf
    Power for power, these are slightly larger than the ATS one that Andrew found was obsolete. But, they go up to 32kVA - more than enough to run the Tesla HPC.
    I called the company (the number has changed to +44 1582 882332, by the way) and got the following list prices:
    8 kVA - £4466
    16kVA - £5888
    They said that they can normally reduce those by 10%.
    They also said that a Scott T transformer would do what we are looking for, for a lot less money, however the efficiency isn't as high.
  3. #33
    Junior Member Alpine Driver's Avatar
    Mar 2008
    Austria
    dpeilow,
    thanks for this find.
    Now we have the confirmation, that it IS (would be) possible to charge the roadster, even in continental DACH europe, with 70A (in the 16kVA case: 69,5A).
    The negative issue is the price; I have converted it and xe gave me 6.868 EUR for that value. Lets reduce it by about 10% to 6k EUR - but as for industrial electronics, you surely have spoken about prices excl. VAT - so here in austria we have 20%, which means we are at 7.200 Euros. And then there is transportation costs.... its not mentioned how "heavy" the device is, but from the dimensions and the looks ...
    Another problem is heat dissipation. Datasheet says under load, for every 1000W load -> 100W of heat are generated. So when charging with 16kVA, you have constant 1600W of heat generated from the device (seems to comply with the 90% efficiency).
    So just imagine, for the charging time of 4 hours, a heater blower with 1600W is running. This will result in problems. For charging, less ambient temperatures are extremely important. See tread "energy consumption while sitting", etc.; at TM owners section. With that heat source, you wont efficiently charge, and in summer, you simply have a problem in your garage.
    So, depending on the size of your garage, add 4k EUR to EUR 8k for a stationary air condition including installation.
    But then - with the air condition running - see overall energy efficiency (AC, Inverter, roadster itself).
    Hmm. I like the Schieflast more and more
  4. #34
    May 2008
    Winchester, UK
    You can see that there is no size advantage and certainly no price advantage of taking the smaller converter over a readily available UPS, in this case. But the option is there.
    As for heat dissipation, how much heat does the Roadster itself emit while charging? If it takes >70kWh to fill the 53kWh battery, this suggests 1/4 of the 70A from the HPC is going into heat, in which case 1kW from the phase converter is the least of your worries. Best get a heat pump and warm your house .
    I found an interesting thread here. An Indian supplier is talking about doing this with a transformer
    EDIT: So I've been thinking about this one and it is puzzling me. I think it is incorrect. The instantaneous voltages in the secondary coils add up to zero. Check by adding up the vectors for the coils in series and you get zero. I'll admit to it being a good few years since I last did this, but can anyone verify this guy's advice?
    Last edited by dpeilow; 08-19-2009 at 04:11 PM. Reason: don't believe everything you read on the internet
  5. #35
    Mar 2008
    Austria
    I could add some photos of my power outlet on my flickr album:
    Flickr: teslatuning.com's Photostream
  6. #36
    May 2008
    Winchester, UK
    So what they've installed there is a 5 pole 3 Phase + Neutral + Earth IEC 60309 socket (Y connection) which is fully submersible and rated at 63A for 6 hours.
    What is the device at the back on the heater?
  7. #37
    Mar 2008
    Austria
    This is a Schell Easycount 3 electric meter:
    Manufacturer:
    Schell Count -
    Never trust a VDS
  8. #38
    May 2008
    Winchester, UK
    Quote Originally Posted by dpeilow View Post
    Seems my inkling was correct (At least my arithmetic was ok after having not done any AC circuit calcs for 15 years - and that was at school).
    I asked a supplier to look into this circuit and just got the following response:
    Actually David it is impossible to achieve a balanced loading on a three phase system when supplying a single phase load with a transformer
    The phase shift between the three phases means the circuit you have proposed will result in an output of 0V
    There are two methods of obtaining a balanced load
    1. A three phase to single phase inverter
    The three phase is converted to DC then a single phase sine wave AC is created by switching electronics
    The three phase supply only sees the DC as a load and is thus balance on the phases
    2. A motor generator set
    A 3 phase motor is powered by the supply this mechanically drives a single generator
    The supply only sees the motor as a load and is thus balanced
    There are several methods of converting 3 phase to single phase with a transformer but you can not get a balanced loading on the three phase system with just one single phase output. It could be possible if the load can be distributed between say two single phase ring mains
    So there you have it. I'd already discounted the motor-generator method as being inelegant, but maybe it is worth a look again. The last paragraph is essentially talking about the Scott T transformer - it needs two separate loads to be efficient.
    So it looks like it the rectifier-inverter (or UPS) is the best method, at least until Tesla lets the cars take three-phase directly and obviates the need for the inverter.
    By the way, small, high-power three-phase rectifiers are available.
    Bridge Rectifier, 800V 150A 3-Phase, Sanrex DF150BA80 at The Electrostore.com - Electronic Surplus Parts & Equipment
    Powerex Grids
    But, this is only half the story.
  9. #39
    May 2008
    Winchester, UK
    I found a great presentation on the Mennekes EV connector standard for Europe here.
    For those charging at home with 32A, check page 27.
  10. #40
    Mar 2008
    Austria
    great presentation!
    I did not know of the electromechanical interlock - so no "mobile connector" - no cable can be stolen!
  1. Problem with new style and old version of FireFox
    By DuncanWatson in forum Site Feedback
    Last Post: 08-16-2012, 10:59 AM
  2. EV Charging - Japan Style
    By AndrewBissell in forum News
    Last Post: 03-11-2011, 05:59 AM
  3. NYpost: Ride in Style
    By TEG in forum Video
    Last Post: 07-15-2010, 09:01 AM
  4. Tesla drag racing - UK style
    By dpeilow in forum Roadster
    Last Post: 05-17-2010, 08:20 AM
