Making a UMC extension cord
I'd like to create a UMC extension cord that would connect to the UMC on one end, and the UMC adapters on the other end. The cable would pass the pilot and other signaling necessary for the UMC to deduce the correct charging rate based on the attached adapter. This seems like a safer (although still not "official") option than a NEMA 14-50 50 AMP extension with "dumb" adapters that then connect to other (potentially <50 amp) plugs.
Anyone know where I could find the necessary male and female connectors to mate to the UMC to build this, short of cannibalizing a UMC and adapter?
I really don't know why one would go through the expense and trouble of making something like this, when a properly sized extension cord would work just fine for a fraction of the cost.
25' of the proper 8/3 SEOOW 40A cable costs $60 from Amazon:
Coleman Cable 096040008 SEOOW SEOPRENE, 8/3, 25-Foot - Electrical Wires - Amazon.com
This is $2.40 per foot. The same cable that Tesla uses for the UMC with control wires costs $5/foot (plus shipping)
I don't see the need to use it, and, the connectors tesla uses are proprietary, so you would have to have it custom made, it's just not worthwhile from almost every perspective.
If you want the same cable Tesla uses for the UMC, it is availble here:
J1772 Cable
No one has done it, probably can't be done safely. The UMC end is a Tesla proprietary connector. Tesla itself doesn't even have a generic connector that plugs into the UMC - all Tesla parts are integrated with an electrical male plug. I suppose if you were really handy with a 3D printer and a lot of trial and error you could make a part, but your guess is as good as mine whether it would reliably work with 40A currents running through it.
NEC Table 400.5, column B: 8/3 is limited to 40A interactive duty or 32A continuous duty for 240V-only use - (EV charging is always considered continuous duty). 6/3 is required.
Yes, strictly following code that's true. You might want to look at the high temperature insulation on the SEOOW cable I specified.
You do know that Tesla is using (2) #12 wires paralleled for the UMC cable (per leg). Also high temp insulation.
You can also get 6/3 SEOOW, it's overkill considering what tesla is using on the UMC itself.
Coleman Cable 096030008 SEOOW SEOPRENE, 6/3, 25-Foot - Electrical Cables - Amazon.com
Here is the spec on the 105 degree C insulation and 40A ampacity rating for the 8/3 SEOOW cable
https://www.ccixpress.com/wcsstore/CCIxpress/images/catalog/catalogPDFs/2-/22316.pdf
Yes, I'm not a fan of Tesla's setup in the UMC, I understand it makes things a bit more flexible but it leaves more failure points IMO. 400.5 doesn't make any distinction for insulation temperature or even service type on the cord (J vs. standard vs. E).
Of course, just by using an extension cord, you break code anyway, if we accept that we're going to use one we've decided to go out of bounds anyway. :)
Might the combination of these two gizmos be a slight variant solution to the op's request in seeking a "smart" mid-stream Tesla UMC extension cord that provides proper signaling from QuickChargePower.com?
