Batteries work better when the cells are closely matched for both capacity and internal resistance. Replacing a few here and there might actually make it less consistent and less stable. The other problem, at least with the Roadster, is that it takes about 12 technician hrs of shop time to swap out the ESS. Not something I want to pay for every 3 yrs.
I can indeed pull out any single 100 amp hour cell and replace it fairly easily, one reason most of us DIY types don't use the higher density but more difficult to build with 18650 LiCo cells. However you wouldn't want to stick a single cell with different specs into the pack as it would make management difficult, though not impossible. Actually as long as it had the same voltage range and had larger capacity than the other cells it wouldn't matter too much. It would just have an easier life being shallow cycled compared to the others.
