Having two all electric vehicles, grid tied solar with backup, and currently experiencing my second extended outage due to bad weather, I feel qualified to make a few comments.
Recharging off of solar during an extended power outage may be possible, but not practical. Let's take your average 60 mile commute. At a nominal 300Wh/mile you will use 18KWh of energy. Normally if charging off of a 40amp/240v circuit you would charge at a rate of ~10KWh. So it would take you ~2 hours to charge.
Now lets look at solar. We have a medium size 10KWh residential solar array. During the winter months the average production is about 15KWh/day (range 0-40). In the summer the average is ~40KWh/day (range 0-60). So for an average winter day if you used all of the solar energy for charging you would not meet your average electric vehicle need. If you got lucky and had a sunny day in the winter then you would be in a better situation.
Note that this is if you used ALL of the solar production for charging. In reality you probably still want to supply the house. So on the demand side, running only the bare essentials (well, air handlers for heat, septic, fridge, a few lights and TV/computer), we average about 15KWh. So on an average day solar supplies the house with nothing left for charging. On a good day you will have extra for charging. But who knows whether it will be a good day or bad day after a storm!
We have battery backup which buffers the good day/bad day variation and also allows us to have electricity at night. So if we have a 0KWh day of solar we can use 15KWh from the batteries. Then hopefully the next day will be a 30KWh day to run the house and recharge the 15KWh energy used from the batteries. This includes no electric car charging!
So my recommendations for recharging BEV for use during storm outages.
1. Charging ahead of a storm with an expected outage is a priority! Odds are you won't even need to recharge before the power comes back if you take this one simple step.
2. If your power is out at home you can usually find some charging near your destination/work. If the outage is so widespread that you can't charge at work you probably won't be going into work and hence no need to drive long distance. Around here if the power is out the streets are closed from downed trees and wires.
3. The majority of residential solar installations stop producing electricity when the grid goes down to prevent back feeding the grid. If you want to use solar in an emergency you will need a system that "islands" itself to keep it on when the grid goes down. If you are going to do this you will probably want to add battery back up for night time electricity.
4. A quality backup generator for charging is probably better than relying on solar for charging unless you have a really big solar array (>20KWh) or a really big battery backup capacity (>60KWh).
