That could be the connection that has Elon excited again.
Yes, I guess this part: "which have the advantage of delivering fast bursts of power and can be recharged hundreds of thousands of times without losing much capacity" makes them good candidates for use in hybrids. The article doesn't really indicate whether doubling the capacity, which they hope to achieve by the end of the year, would already make them competitive also on a price basis, but it seems they may be able to achieve 40 watt-hours per kilogram using the not-so-expensive conventional electrolyte.
If it is true that they could "eventually" achieve "500 watt-hours per kilogram", then that would certainly put them in the range that Li-Ion may have in several years (hopefully), or even above. Same for the cost, if they are able to achieve "$150 per kilowatt-hour". Though that sounds very very optimistic.
They say "$2,400 and $6,000 per kilowatt-hour." Given a hybrid usually uses 1-2kWh, it's a bit high. I know the Honda replacement battery costs $2k and it's ~0.9 kWh. Prius replacement battery is $2,588 and ~1.3kWh. That's price to consumer too (not bulk price). And the cost is only coming down in recent years.
Interesting they don't mention power density or cost per kW as that is more important for hybrids. Volumetric density matters too (the brake backup supercaps in the Prius and the Leaf actually take up a lot of space; for the Leaf it takes up a big chunk of the "hump" in the trunk). Anyways as a whole, I feel they have a decent chance in the hybrid market, but still a long way to go before being adequate for EVs.
Because there are tons of crazy people in this world...
Electric power = voltage times current. Miniaturization reduces tolerable voltage. Electrical engineer Martin very skeptical. Other problems: Electric double-layer capacitor - Wikipedia, the free encyclopedia .
Rice University | News & Media
Rice University researchers have created a solid-state, nanotube-based supercapacitor that promises to combine the best qualities of high-energy batteries and fast-charging capacitors in a device suitable for extreme environments.
Buying an EV is one thing, being able to drive it beyond city limits another...
Another day, another university breakthrough.
Lets see the game changing products hit the market already!
...continued...
This seems to avoid some difficulties associated with some other super-caps, however here:But traditional EDLCs rely on liquid or gel-like electrolytes that can break down in very hot or cold conditions. In Rice's supercapacitor, a solid, nanoscale coat of oxide dielectric material replaces electrolytes entirely.
The researchers also took advantage of scale. The key to high capacitance is giving electrons more surface area to inhabit, and nothing on Earth has more potential for packing a lot of surface area into a small space than carbon nanotubes.
ScienceDirect - Carbon : Three dimensional solid-state supercapacitors from aligned single-walled carbon nanotube array templates
they merely talk about "the ability to achieve energy densities above 10 W h/kg", which doesn't seem interesting for EV energy storage, but there seem to be other areas of application. And interesting in so far as they seem to develop more and more ways to use nanotech.
This seems to be an early research result, unlike the use of nanotubes as an alternative to copper for wires (currently same conductivity at a sixth of the weight) which I just posted in the Off-Topic section, for which they are now working on a manufacturing process (i.e. ready to leave the lab).
