Page 4 of 14 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 140
Thread: Gas stations are dangerous!
  1. #31
    '08 #383 SByer's Avatar
    Oct 2007
    Cupertino, CA
    And that's just with gasoline, which is flammable but not explosive. Compressed hydrogen would be another beast altogether...
  2. #32
    May 2009
    Zurich
    Quote Originally Posted by SByer View Post
    Gasoline and Hydrogen are very different. Both can be ignited when mixed with air (gasoline vapours), but Hydrogen needs less energy for the reaction to be triggered than gasoline vapours do. Gasoline vapours explode only in a fairly narrow range of air admixture, whereas hydrogen goes off across a much wider range (as does alcohol). Hydrogen is of course very difficult to contain and leaks easily (goes through glass e.g.). To build hydrogen tight assemblies for a car rattled across cobblestones is not a trivial exercise. Be careful with alcohol and your barbecue, the bottle can already go off when you open it (static spark will do).
    Alfred
    ______________________________
    http://alfredg.homepage.bluewin.ch/
  3. #33
    ERIC VFX vfx's Avatar
    Aug 2006
    Hydrogen Stations are Dangerous!
    (worth a new thread)
    With as few stations and cars as there are now, I wonder what the accident rate is in relation? One explosion per every "...16,000 hydrogen fill ups by over 800 drivers." does not sound that good to me. I that all hydrogen stations and all cars?
    How does that compare with gasoline and electric power station explosions?
  4. #34
    Electrics are back mpt's Avatar
    Oct 2008
    Warren, New Jersey, United States
    Blog Entries
    Quote Originally Posted by Alfred View Post
    goes through glass
    Don't mean to derail the thread but... wow! That to me sounds like the sort of quote that would really hit home just how impractical hydrogen is; it's the sort of thing that makes sense to the common man.
    I plan to use that if you don't mind.
  5. #35
    Aug 2006
    That line struck me too. I will also use it.
  6. #36
    Status: Reserved
    Jan 2010
    Oslo, Norway
    A couple more facts:
    The H2 molecule brownian motion is faster than the Earth's escape velocity, so our gravity field can't contain it. When released into the atmosphere, it eventually escapes into space. Talk about hard to trap!
    A hydrogen fire is almost invisible in daylight. Earlier, NASA trained its firefighters to wave a broom about in front of them if they suspected a hydrogen fire - the broom would then catch fire first, so the firefighter could avoid walking right into it. http://www.sti.nasa.gov/tto/spinoff1997/ps1.html. Quote NASA: "Indeed, hydrogen fires are a significant risk". This goes for alcohol too, by the way.
  7. #37
    Now P76 before P121
    Jun 2007
    Oslo, Norway
    Yes I can gladly attest to this. Having used a hydrogen flame as a blowtorch the flame is pretty scary. When you purposefully turn it on and use it the heat distorts the gasses around the flame so you can actually see it. Though the effect is pretty subtle and at one point I almost put my hand through the flame as I thought the burner was off. It does make for a nice indoor flame though since there is no carbongas buildup
    Cobos
  8. #38
    Senior Member tdelta1000's Avatar
    Jul 2009
    South Florida
    WOW!!!!!!!!! Thanks goodness there was no fire.
  9. #39
    Saving up for a Model S
    Jan 2010
    Utah
    CJ Barlow
    "Until we see every car on the road being electric, we will not stop." - Elon Musk
  10. #40
    Administrator dpeilow's Avatar
    May 2008
    Winchester, UK
    Sort of counterpoint...
    Neil Young warehouse fire started in car
    A fire at a warehouse owned by Neil Young started in a 1959 Lincoln Continental car he had converted into a hybrid vehicle, authorities have said.
  1. Gasoline is dangerous
    By richkae in forum Off Topic
    Last Post: 05-21-2012, 10:42 AM
  2. Gas Stations in Japan Offering Charging
    By dpeilow in forum Asia and Australia
    Last Post: 12-29-2011, 10:34 AM
  3. Dangerous sticker
    By Mitrovic in forum Roadster
    Last Post: 04-10-2011, 12:15 PM
  4. Replies: 0
    Last Post: 02-01-2009, 12:37 PM
  5. Replies: 0
    Last Post: 10-03-2008, 08:10 AM
