My charge port door has started to stick on occasion. I hit the button on the UMC/HPWC and I hear a click, but the door doesn't open. If I repeat this a few times eventually it will open. The easier thing seems to be to push on the far right side of the door after hearing the click (presumably a lock releasing) which overcomes whatever is causing the door to stick.
Has anyone had any success using a lubricant on the door hinge or around the edge of the door to fix this issue?
Andrew
Andrew
