Page 11 of 41 FirstFirst ... 78910111213141521 ... LastLast
Results 101 to 110 of 403
Thread: Coda Automotive (formerly Miles Automotive Group)
  1. #101
    Jul 2008
    Queens, NY
    Peeking under Coda's hood
    Interesting pictures posted on ABG under Coda sedan's hood.
    1. Radiator visible upfront cools power-electronics. I find this layout a bit strange, since it's traditional, but air is drawn through radiator by cooling fans (presumably from below), not due to motion (as air intake is closed off). Wouldn't hot air be pushed onto said electronics directly behind the radiator then? It seems it would be better to arrange radiator horizontally above electronic modules (similar to CPU cooling) and push air out via some kind of hood scoop.
    Would give the Coda a nice "performance" look as well.
    2. Battery visible on the right is lead-acid kind and is used to power accessories.
    3. 33.7kWh, 333V lithium-iron phosphate battery main traction battery is manufactured by Tianjin Lishen Battery. There was talk of forming a JV with Yardney Technical Products to produce batteries in the U.S., but that deal fell through due to JV not getting DOE grant money.
    4. I presume due to competitive development, we have movement on the price front
    Czinger told Scott that the sedan will likely sell for around $32,000 (after rebates), which is lower than the price announced in June of $45,000 (before incentives)
  2. #102
    Head Moderator / Administrator doug's Avatar
    Nov 2006
    Stanford, California
    Blog Entries
    Quote Originally Posted by Serge View Post
    There are some updated photos on Paul's blog: EVs and Energy: Coda Review
  3. #103
    Compared to an ICE, EV is so much more efficient so that cooling needs are less.
    They probably used the stock ICE ready radiator (to save costs), but it ends up being rather oversized for the cooling needs of the electronics... So it doesn't need much airflow to keep things in order.
  4. #104
    Quote Originally Posted by doug View Post
    Odd, the "updated" photos look like more of a prototype than the ones on AutoBlogGreen.
    For instance, the Optima Yellowtop 12V aux battery on Paul's blog compared to some smaller, generic, cheaper battery on ABG. Also some of the control electronics looks more production intent on ABG.
  5. #105
    Jul 2008
    Queens, NY
    Quote Originally Posted by TEG View Post
    That makes sense. The only problem I have is with hot air being blown back onto electronic modules that are being cooled. At the very least, I hope they add some air shrouds to route hot air away. Otherwise the design looks half-baked to me.
  6. #106
    Nov 2006
    Blog Entries
    Instead of "updated", it might have been more clear if I said "more recent". Those pics are of whatever car they used at the ride event.
  7. #107
    Well I suppose it "works both ways". On a cold day having the radiator warm the air before blowing over the electronics will help keep them uniformly warm.
    Given the limited amount of heat being generated, I think this system is more about uniform temperature distribution and overall thermal mass, and not so much about airflow. As you mentioned, the front grill cover blocks much of the airflow so there isn't so much air movement through that radiator.
  8. #108
    Yeah... So, in other words, they likely used an earlier prototype for the test rides. Sortof like giving rides in an EP instead of a VP...
  9. #109
  10. #110
  1. Bright Automotive
    By vfx in forum Electric Vehicles
    Last Post: 02-29-2012, 11:59 PM
  2. Friedman on China, Coda Automotive, batteries, Shai Agassi, & gas taxes.
    By Brent in forum Energy, Environment, and Policy
    Last Post: 09-27-2010, 10:25 AM
  3. BG Automotive - C100
    By dpeilow in forum Electric Vehicles
    Last Post: 03-18-2009, 07:25 AM
  4. Replies: 3
    Last Post: 12-17-2008, 04:53 PM
  5. Miles Automotive Photoshop Wizardry
    By Kardax in forum Electric Vehicles
    Last Post: 11-14-2007, 12:15 PM
