Door Handles: Warning! Random Door Opening While Locked!
Doug_G
Lead Moderator
Global Moderator
Apr 2, 2010
17,888
3,421
Ottawa, Canada
I've had the car one month, and have had this happen twice now.
This morning at 10:47 am I parked the car at a local mall. As we walked away I hit the FOB to lock it and watched the handles retract. I was being careful because we had some valuables in the trunk (laptops).
When we returned at 11:37 am there was a guy taking pictures of the car. He told me, "Do you realize your back door is open?" Yes, my left rear door was indeed open, and all four doors had their handles extended. The car was completely unlocked! There is no explanation other than the car unlocking itself and opening the door while unattended.
This is actually the second time this has happened to me. The previous time it was the rear right door.
Update: Tesla replaced the offending door handles.
I do hope you reported this both times?
I would assume so, but you didn't mention what Tesla told you, or if they were able to tell anything from the logs?
While I don't know, I would hope any commands issued my the control system would be logged.
Please keep us updated on the resolution.
I'm sure you've thought of this, but do you have it set up to auto-present the handles? Do you suppose as you were walking to the car, the handles simply presented in the normal manner and then the random door opening occurred as has been documented by others? Or maybe there was some stray RF interference that the car mistook for your fob, presented the handles and accidental door opening as per above? Could someone else's remote access fob have interfered?
I'm still suspicious of the mechanical handles. I wonder if something cause the car to think you were there (stray RF, someone else's fob etc.) which initiated the unlock and extend sequence and then the too sensitive (in my opinion) door handles popped the door.
Aside from the discussion of the retractable handles being practical, do we know why Tesla made it so that the car actually pops open the door vs pulling the handle releasing? If the car didn't have the ability to physically open the door, that would be less of a problem (and would also prevent getting locked out when the car doesn't recognize that you're pulling the dang handle).
I do have it set to auto-present; however, this time I had a witness who had observed the open door before I arrived.
I really doubt stray RF or another FOB could cause this. Canada has stringent requirements on how the FOB coding system operates. It would be a miracle.
Tesla uses an electric solenoid to release the door. This is not uncommon. My current ICE does the same thing, but uses a more conventional handle that requires an inch or so of travel before the switch that activates the solenoid is closed. The Tesla handle seems to need a very small amount of travel (maybe it's just a bit of pressure) to trigger the switch, and I (personally) believe this is the root cause of the random door openings. Other owners have reported that handles had to be replaced to correct the problem, and this is likely because the switch is too sensitive.
- - - Updated - - -
You're probably right about the RF, but something caused the car to think you were nearby. I might suggest turning the auto presenting handles off until Tesla sorts this out (I believe a too sensitive switch is triggering the solenoid when the door handles extend).
