Cool. Wonder if it charges with 3 phase?
Well for a 100 mile range at 250 Wh/Mile consumption, and an energy density of 250 Wh/L, you'd only need 100L of battery space, I suppose you need to maybe scale that up some for casings and cooling space but generously maybe to 130L? That's about a tenth of a cubic metre plus a little bit as a rough guess. Surely that doesn't use all of the space freed up by removing the engine, gearbox, driveshaft and exhaust tunnel?
Edit: Just seen the diagram from TEG. Looks like it does use all the space! Very narrow underfloor module though.
Last edited by JimmWilks; 04-11-2011 at 12:47 PM. Reason: New information relevant to original posting.
A lot of these conversions seem to use the T-shaped battery, even the Leaf. Highlights how efficiently packaged the Model S battery is.
The Leaf battery isn't really "T-shaped":
It is shaped to fit humps under the seats.
Ah ok so it isn't, I didn't check before posting, and was relying on my apparently faulty memory! Actually looks like quite efficient packaging also.
Judging by this picture, it looks efficiently packaged but TINY compared with the Model S battery size. I suppose with the range difference that is to be expected. Still, if I were building an EV, I would be tempted to fill all available space with battery.
I think Nissan put less battery than they could because they were targeting a low price of entry with range on the low side.
If you need a bit more range, and want to spend more you could look at a CODA.
They are having enough trouble just making enough of one model. You can't just drop some extra cells in place and call it a day, you either have to add cells in parallel to each existing module to keep voltage the same or you add modules in series, which increases voltage, which might be more than the controller, DC/DC, and charger are made to handle. Plus the suspension might have to be different to handle the extra weight, and it might even call for more crash testing because of that.
