Got my car today and followed up on this.
You can change while moving.
It will lower down on its own from very high: first to high and then to standard. it takes About 90 minutes to change all the way to standard while parked.
You can use jack mode to stop it from lowering.
Don't park over a park stop!!
P427 Performance White/Tan
Good to know - thanks contaygious
Sufficiently advanced magic is indistinguishable from a rigged demonstration.
DISCLAIMER:
1. Do not copy anything that I post outside of the TMC forum without permission.
2. Any advice or opinions posted here are to be taken as my personal opinions only. There is no implied warranty, fitness for purpose, or official statements from any company I may have been or am affiliated with.
3. Even the best recommendations are wrong when used inappropriately.
I think I got bitten by this issue last night. I parked the car with the front lip slightly over a curb. There was no sound when I pulled in. When I left, there was a slight scraping noise. Nothing huge, but I suspect that the car did lower after I parked it.
R129 - 85kWh White/Tan
I still feel it shouldn't do this. I've never had a car with air suspension "settle" and secondly, there is a big thread on towing where it is explained that the reason you have to flat-bed the car is because the suspension continues to "auto level" even when the car is "off".
Sorry, but I'm hyper-sensitive to this issue. My current car has a very low front air dam, and in spite of serious attention, I have managed to "bump" it on curbs a couple of times. The last thing I want is my car hitting curbs on it's own. If I park with the nose clearing the curb, I expect it to be that way when I return.
I've been leaving my car on the settings screen when I get out. So far it has usually been lowering the car from very high to high by the morning. Sometimes it even stays in very high. I have not seen it go back to standard like the rep told me it would, but I have always been checking in the morning just in case before I leave down my curb.
Good point. I had wanted the air suspension, but may want to re-think that. I have had air suspension on past cars, and when they worked, they were great. I did, however, have problems with leaks in the system that were fixed under warranty, but I always worried about a failure after my warranty ran out (never did have an out of warranty failure).
I don't believe any non-air cars have gone out yet. Is this true?
